ORIGINAL: lov2flyrc
Shaun,
Did you prime the tube first (initial squeeze out without nozzle installed until both sides even?). We use quite a bit of the 9462 in-house as well and have only had a few bad tubes over the years with the exception of one bad batch about 18 months ago (all cases sent back). At the rate we sell (and use) Hysol, our stock is indeed fresh! Should have called me if you had a problem!!
Todd
Hi,
Thanks, Todd. I thought I did mention the problem, but it's probably my mistake. In this case, I squeezed the subsequent tubes from the gun without the mixing tip on after the first one did what it did. I thought it might have been my gun, so I used a different gun with the same result. I chalked it up to a bad batch. It was the strangest thing, though....as I squeezed the gun, you could actually see one side pushing through, but the other not. If I had been thinking better, I'd have squeezed the uneven volumes into something I could have saved the glue with (for hand-mixing).
I use the tips almost exclusively. For me, they're half the point of using this adhesive. Tack stuff in place, then caulk a bead around it and fillet it in with a gloved finger. If it's for a small application where it's not worth losing the glue stuck in the tip (although I freeze the tip and get a day's stay out of it), then I mix it with a stick.
