RCU Forums - View Single Post - Fastest/Best Source for Hysol?
Old 11-19-2008 | 07:15 PM
Kelly W
Default RE: Fastest/Best Source for Hysol?
Hey Guys.
Don't want to change the subject, but thought I would add this...
For those using the short mixing tips, I was told by the local Henkel-Loctite rep up here that they won't mix it well enough for an optimized strength joint. It will work OK, but apparently if you want a full strength joint (to the published spec) use the longer tips or squirt it in a cup and thoroughly mix it by hand.
Kelly
