ORIGINAL: Kelly W
Hey Guys.
Don't want to change the subject, but thought I would add this...
For those using the short mixing tips, I was told by the local Henkel-Loctite rep up here that they won't mix it well enough for an optimized strength joint. It will work OK, but apparently if you want a full strength joint (to the published spec) use the longer tips or squirt it in a cup and thoroughly mix it by hand.
Kelly
I believe that is true.
