RCU Forums - View Single Post - Kyosho Osmose 70, Sort of build thread (slow..)
Old 11-20-2008 | 03:50 AM
  #50
Thinn
Default RE: Kyosho Osmose 70, Sort of build thread (slow..)
Finally, I completely finished the model.... (Maybe mayden this weekend??)
I made a new battery pack (4cell Sanyo NiCd1100mAh), put in the reciever and set up all servos etc. I just copied the program from my Oxalys, so setup should be a bit quicker than normal (hopefully...).
Here are som engine pictures. Note the simple, light plug connection... Fuel tubing is an undervalued tool!
And the elongation of the needle....well.. amazing what you can use those T-end building pins for!
ID:	1075454   Click image for larger version
ID:	1075455   Click image for larger version
ID:	1075456   Click image for larger version
ID:	1075457   Click image for larger version
