RCU Forums - View Single Post - ZXX engine interference
Old 11-20-2008 | 03:31 PM
  #42
mrc-hirobo
Default RE: ZXX engine interference
congrats, but it seems highly unusual to have to sand down the clutch liner unless it wasn't a stock Hirobo liner replacement.
make sure the clutch shoe-to-liner gap is less than 0.5mm. If it is more then this then you will over stress the shoes and they could break.
also, make sure you get a antenna tube for that antenna and isolate it from anything aluminum.
also, on the Enya, just a FYI, MRC no longer supports or carries Enya, so if you need plugs or engine parts you'll have to go to Enya or whomever is their current distributor.
good luck!
