RCU Forums - View Single Post - main shaft replacement
Old 11-21-2008 | 03:17 PM
Druss
Default RE: main shaft replacement
Should be in your manual. I don't have one myself but on most helis I'd completely remove the head as one piece first. Just remove the bolt holding the main gear on, remove the links from the servos and pull the entire head out. From there you have to remove the jesus bolt then you can probably slide the rest of the head off.
