blubbering on
HI it sounds like there is a small air leak around the carb. You need to find some o-ring lube...I think it is a silicone based lubricant....and reinstall the carb. This extra grease might seal the leak. Do not use petroleum based grease on o-rings! It will deteriorate them in short order!
Hope this helps!
Regards
Mark
