Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Does yours turn off like a switch or does it blubber on a bit? >
Old 05-30-2003 | 02:28 PM
Default Does yours turn off like a switch or does it blubber on a bit?
OK, I fixed my Irvine .39 not shutting down problem by making sure that the carb is pushed down firmly before tightening the bolt; But:
When you shut the throttle down, it still wants to blubber on for a couple of seconds before actually quitting.
I'm almost sure that on my air bleed carbs (OS LA) they shut down immediately, so -
Do yours shut down immediately (almost like a switch), or
do they blubber on a bit?
Old 05-30-2003 | 02:31 PM
barto's Avatar
Hi,
I have a .40FX and it shuts down immediatly. No blubbering
Old 05-30-2003 | 02:54 PM
3D Joy's Avatar
Same on .61 SF-P --> instant stop.
Old 05-30-2003 | 10:49 PM
mstroh3961's Avatar
Default blubbering on
HI it sounds like there is a small air leak around the carb. You need to find some o-ring lube...I think it is a silicone based lubricant....and reinstall the carb. This extra grease might seal the leak. Do not use petroleum based grease on o-rings! It will deteriorate them in short order!
Hope this helps!
Regards
Mark
Old 05-30-2003 | 11:57 PM
.25FP , 2 46FX'es , 40LA , 2 46LA's all shut down like a switch ... check that o ring man.
Old 05-31-2003 | 01:47 AM
I have heard of those problems on the Irvine, GMS, and Tower (GMS) engines...Seems common with all of them. All the engines I have ever had shut down real quick with the throttle closed. No problems...
Old 05-31-2003 | 03:12 AM
Thanks,guys... I'll look into the O ring lube..
Old 06-09-2003 | 02:41 PM
Default Lube?
Found some stuff in the auto store the other day, I think it was caleed di-electric grease - used for spark plug caps etc.
Anyway it said 100% silicone.
The engine still runs on a bit, but at least it does shut down....
Old 06-09-2003 | 03:28 PM
Default Re: Lube?
glad to here it
