RCU Forums - View Single Post - Fastest/Best Source for Hysol?
Old 11-22-2008 | 11:44 AM
B Carter
Default RE: Fastest/Best Source for Hysol?
I work for Fastenal here in TN and I buy the Hysol 5 minute epoxy and the 24 hour epoxy along with the tips. There is no difference except in the price between the Hysol and Aeropoxy. My assumption is that BVM has Henkel products (Loctite) private label the cartidges. You can also buy your 4mm and 6mm unions as well as bulk head fittings from us as well. We do not carry "Festo" we carry Legris and Alpha fittings. I have no trouble out of either of these. I will list some part numbers below and you can go to your nearest store and pick these up. Let me clarify...these are not part of our store inventory model but are in our distribution system and are many times one to two days away.
0150484 - 5 minute Hysol
0207288 - Form Release...makes GREAT Smoke oil
0442621 - 6 mm bulkhead fitting
0605217 - Applicator gun for Hysol
442048 - 4 mm union
442013 - 6 mm union
I dont have the part number for the 24 hr epoxy but if you tell your representative that you want a Hysol (Loctite) product with the model number you are looking for they can look it up real easy. Same with the long and short nozzles. Seeing as I work for Fastenal I would like to see you buy from us rather than the Grainger guys.
Hopefully this helps
If you want more information email me at [email protected]
Brad
