RCU Forums - View Single Post - Nitro Models Kangaroo Modified
Old 11-22-2008 | 03:35 PM
  #39
steinericj's Avatar
steinericj
Default RE: Nitro Models Kangaroo Mods - Sheeting
Well I finally started building mine after all these months. I'm going stock with fixed gear and OS 46 FX. So far I have the folling to report:
- Covering is very nice
- Wing and stab fits were good except supplied dowel pins are to small
- All servo holes had to be enlarged
- Nose gear blind nuts did not align with holes in supplied nose gear block
- Main gear blocks were to small for openings - had to make larger
- Motor mount holes did not line up with preinstalled blind nuts
- Fuel tank and nose gear block are difficult to install - poor access
- Since this is a pusher - I installed the tank with the stoper facing back but installed a brass tubing "U" bend inside tank so klunk is at stopper end of tank.
Here are some pictures....
ID:	1076968   Click image for larger version
ID:	1076969   Click image for larger version
ID:	1076970   Click image for larger version
