ORIGINAL: evdreamer
1. Do you have a CP or a CP+? Because my CPP had enough power with the stock motor to lift off the ground easily. If you had the original CP with the NiMh battery I can see it having some problems with the added weight of the battery. Try lowering the pitch also.
2. It sounds like you need to adjust the proportional pot. CCW to give more power to the main motor and less to the tail motor.
3. You need to have the throttle trim all the way down and the throttle at the 0 position or the 4in1 or 3in1 won't arm. Then you can add throttle trim if you wish.
4. If the tail looks like it is wagging then your gain is too high. Turn the gain pot. CCW a little at a time until it stops.
Nick
It must be the original. it has a NiHn battery.
2. Check will give it a turn
3. this is not a wagging. I have a GY401 on my Rappy and i know exactly what the wagging is. this is a semi circular ossiclation when you go full stick one direction th rotor tries to match the ossiclation. its weird. prehaps its because the torque from the rotor is not enough. Ill see if it still does it after i change this stuff. thanks for the fast response and the help.
One more thing. the controler on this thing, the Yaw is on the left, this is normal. the pitch/throtle is on the right stick??? the roll is on the right and the elevator is on the left. if i got all that right. is this a standard confi for this heli? the left stick auto centers on both axis and the right one only on the left/right axis weird....
