RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 11-23-2008 | 08:26 PM
  #3331
edward cobb
Default RE: DL-50 engine
ORIGINAL: SU29
Hey guys I just purchased the DL 50 and it has been a while since I have used a gas engine and have a few questions. I need to know where to set the piston / prop for starting and some tips on how to mark the prop / backplate so that I can drill them with the prop drill jig.
Jeff
I have found that the best position to drill is to turn the prop facing you(forward) placing the prop on a horizontal plane. set the drill jig with one hole to the 1o clock position. drill from the front first, reverse the drill jig to the rear and then drill through from the back to true the holes. when putting the prop on the plane, set it as to compression comming to the 1:00 clock position. Ths will best insure fingers are clear on the downward swing of the prop.
