RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 11-23-2008 | 10:27 PM
  #3334
GATTUSO2170
Default RE: DL-50 engine
the oil is again klotz techniplate witch is supposably a hi quality synthitec oil bu here is what there web site says:::
Pure synthetic bases are blended for the perfect level of 2-stroke lubrication and performance. Klotz® Clean Burn™ technology virtually eliminates carbon and residue buildup. Extreme film strength engineered to reduce engine component wear and build horsepower. Blends with methanol alcohol and gasoline.
APPLICATION:
Primary use is in alcohol and R/C Model glow fuels
R/C Modeling – 2/4-stroke glow
Motorcycle/ATV – 2-stroke/alcohol; Stock, Hi-performance
Kart/Micro Sprint – 2-stroke/alcohol; Stock, Hi-performance
Kart/Micro Sprint – 4-stroke/alcohol; Stock, Hi-performance, Road Racing
CHARACTERISTICS:
Smoke Rating: 10 1=fog; 10= no smoke
Clean Burn™: 10 1=heavy deposits; 10=no carbon
Film Strength: 7.5 1=failure; 10=virtually no wear
Viscosity @100°F: 950 SUS 50 W @ 40°C: 200 cSt
Pour Point: -15°F
Flash Point: 460°F
RPM Limit: 12-13,000; R/C Model 20,000+
Rust Prevention: Contain rust inhibitors. Not recommended as a
storage lubricant.
Certification: A.P.I. S.A. Intended for Racing Engines Only
Color: Red
DIRECTIONS:
Compatibility: Blends with BeNOL® castor oil, SuperTechniPlate®, gasoline, methanol alcohol,
nitromethane and stays in suspension. Will not blend with petroleum oils or synthetic lubricants.
100% Biodegradable formula.
Fuel Stability: Will dissolve in gasoline at ratios of 15:1 or greater; alcohol at ratios up to 5:1.
2-Stroke pre-mix: Do not use in oil injection systems.
Air cooled engines mix at 16:1 to 20:1
Water cooled engines mix at 20:1 to 32:1
R/C Model: 2-stroke glow engines mix at 15 -18%
Kart: Air cooled mix at 16:1 to 20:1
here is a link to the site: http://www.klotzlube.com/storeProdDetails.asp?pi=22
