RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 11-23-2008 | 10:37 PM
  #3335
mstam1971
Default RE: DL-50 engine
ORIGINAL: GATTUSO2170
DIRECTIONS:
Compatibility: Blends with BeNOL® castor oil, SuperTechniPlate®, gasoline, methanol alcohol,
nitromethane and stays in suspension. Will not blend with petroleum oils or synthetic lubricants.
100% Biodegradable formula.
Fuel Stability: Will dissolve in gasoline at ratios of 15:1 or greater; alcohol at ratios up to 5:1.
2-Stroke pre-mix: Do not use in oil injection systems.
Air cooled engines mix at 16:1 to 20:1
Water cooled engines mix at 20:1 to 32:1
R/C Model: 2-stroke glow engines mix at 15 -18%
Kart: Air cooled mix at 16:1 to 20:1
here is a link to the site: http://www.klotzlube.com/storeProdDetails.asp?pi=22
That's a high oil ratio. Why not use something else? I'm at 90:1 Amsoil Saber after 8 gallons at the moment and plan to go to 100:1 as soon I'm through the remaining 1 gallon. Runs very clean
