ORIGINAL: WingmanEPTX
my last try was at 325 for 1 hour! i immediately pull it out and tap it on the wood...
-kevin
Do not tap it. Slam it. Grit your teeth. The wood should not damage the aluminum case. Hit it as flat as you can.
Worst case you buy a new case anyways, eh?
