RCU Forums - View Single Post - dx 7 antenna
Thread: dx 7 antenna
Old 11-25-2008 | 08:37 PM
nobodytwo's Avatar
nobodytwo
Default RE: dx 7 antenna
Here's the [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLH1058]link[/link] for the proper antenna. If you replace your own antenna the antenna lead is attached to a circuit board with a "snap" type fastener. The only catch is: it has to be removed and installed in a certain way.
Facing the back of the radio (with the antenna connection exposed) and the top of the radio facing up, the "snap" wire MUST be at the 3 o'clock position to be removed or installed. I've replaced two on a 9303 so far and the first time it took forever, the second about 10 minutes!
Good luck!
