RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 11-27-2008 | 05:02 AM
  #795
Nickolas's Avatar
Nickolas
Default RE: Composite-ARF Integral, kinda build thread
Hi,
Ready to go, the stabs were set again 0.4 degrees negative relative to the wings. Plane is really straight after the rebuild. One action that is currently pending is the modification of the Hyde ARIA mount into normal one and tha installation of a CH nose ring. This will save some grams, the Rud servo is at the tail and have added around 80gr at the tail to balance at the recommended CG, hopefully I will remove this lead after the modification.
Looking forward to the maiden flight v2
Regards,
Nikos
ID:	1079730   Click image for larger version
ID:	1079731   Click image for larger version
