RCU Forums - View Single Post - Next conversion
Old 11-27-2008 | 08:14 PM
captinjohn
Default Next conversion
I got a working CD ignition now so I am going to convert & run this SuperTiger .90. I am going to use 20% oil in gas for lube. I got about 5 mini spark plugs to try. 1/4x32 size. I may tap heat to 10mm later. I am going to bore out the ring hanging on end of propshaft to slip fit on hub. Capt.n
ID:	1080048   Click image for larger version
