Not a problem when you say right wing do you mean right wing as in PILOT VIEW? let me know and I'll replace your right wing with alieron.
Sorry about this
John
Nitro Planes
ORIGINAL: waltroi
Regarding my order yhst-17210252890263-59252 from Nitro Model R C Planes of a Super Low Wing Trainer 40. I received this order and started inventory and ironing out some bubbles. On the right wing half the torque rod was put on at the factory incorrectly causing the aileron to bind on the wing. At first I though they had been glued together. The outside of the wing contours do not align up either, as you would expect due to the main wing/aileron misalingment. This is the third Nitro plane I have ordered this year and this is the first major issue I have had. Please send a replacement wing.
