RCU Forums - View Single Post - Upgrading to RX-18 - smoke unit wire problems!
Old 12-01-2008 | 12:36 AM
atkleiv's Avatar
atkleiv
Default RE: Upgrading to RX-18 - smoke unit wire problems!
ORIGINAL: madbadger
if you look closely there are 4 wires that come from the smoke unit that connect to the motor output joints on the RX13 board, this is the proportional smoke unit, the other two wires from the smoke unit go onto the 2 pin socket on the RX13 board underneath. I haven't got the RX18 board but it looks to me that you just plug in the smoke unit where it says on the diagram, the other 4 wires just De-solder from the RX13 board and connect to either side of the motors, make sure you get the wires right, same two from the RX13 board to the same motor and the same with the other two wires from the RX13 board.
When i replaced the RX13 board with another, i connected the proportional smoker wires to the motors direct, same thing really.
Kev
Thank you for your reply.
Some more questions:
1. I don't think the wires are long enough to reach the motors, how have you done it? Do you have a picture? Is it possible to connect them into the motor power sockets together with the wires to the motor?
2. If I don't connect the 4 wires after upgrading to the RX-18 board, will the smoke unit still work (but not proportional of course)?
A.
Norway
