RE: Refilling propane start bottle
I took a torch end for a propane bottle, removed the long torch section. It is threaded and red locktited but it will come off with a little heat and effort. JB weld or hysol your threaded festo and you're done. Control the flow with the black knob. If you need more flow, just drill out the check ball on the bottom of the valve.
