ORIGINAL: Ryan Smith
Hey guys,
I've seen quite a few airplanes with the Hatori 821 mufflers sport some sort of clear extension. Is there a source for this, I can't find anything in any hobby shops that fits the bill, and this stuff looks to be relatively stiff. It looks to me to be Teflon maybe.
Any help is greatly appreciated.
Ryan,
This appears to be a thick-walled silicone tubing that I used at one time to route my exhaust. Back then, it was available from an American muffler manufacturer that's no longer in business. It is fairly stiff because of the wall thickness of the tubing and heavy for the same reason. I switched to a thin-walled red silicone tubing to save weight. Either can be had at McMaster Carr. You'll also need a spring clamp to hold it in place. Just measure the od of your stinger so you'll know what the id of the tubing needs to be. I'd suggest getting the id a little smaller so you have to stretch it a little to put it on like you would with fuel tubing. Then you'll select the wall thickness. If you want to match the stuff in the photo, the wall thickness will need to be somewhere between .100 to .125. If memory serves me correct, your tubing will have an id of about .5 with an od of about .75 (.125 wall thickness). Make sure your spring clamp fits the od of whatever you choose. Hope this helps.
Verne Koester
