RE: Nitro Models Kangaroo Mods - Sheeting
Sorry to hear about your Kangaroo! You did a beautiful job on it and had very nice mods. I can appreciate all the work you put into it after building mine. Especially the access to the fuel tank and nose area. I built a platform under my tank before gluing it together but was not able to get much foam around it. Hope my tank holds up! Thanks for the info on the antenna - sounds like a good plan. Did you use the throws suggested for aileron and elevator? I will go with elevon and elevator per your recommendation. I used cheap mini servos from Hobby City on the elevator and am not sure how they will hold up. Elevons will give me some additional security. I'll let you know when I maiden it. Probably post a U-tube video also. Weather is very cold and windy out here in Pennsylvania so we are doing almost no flying. Are you aware of any flight videos on this model?
Thanks!
Eric
