RE: Dolphin Fun Fly 50
I have a question on the tail wheel assembly. I can see the aluminum bracket should be screwed to the bottom of the fuselage tail, the wheel shaft would run up through it and glued in the rudder slot. My problem I am having is that the rudder does not swivel on a perfect axis, so if I were to screw down the bracket it will not turn. Got a picture of yours or otherwise I will have to come up with my own solution.
