RE: OS engine convert
Maurice,
You will probably be satisfied with it as-is. If later you feel the need to alter the engine, consider installing a LA .40 piston/cylinder. On the LA, they eliminated the baffle port, probably as a cost reduction. I believe it is a drop-in fit.
Good luck.
George
[/quote]
Unfortunately, the LA .40 sleeve/piston are different than the FP .40 and cannot be used as a drop in replacement.
DennisV
