RE: What do I need to install my RCGF 26cc in a Cub 1/4
Yes you need fuel line for gas as well as fuel pump for gas to fill tank. Also need an ignition switch since now your using a spark plug. possibly a larger heavier duty starter. Also now you will be mixing your own fuel so get right oil and ratio. Amsoil is used by many but most any 2 cycle oil will do but NOT marine.
