RCU Forums - View Single Post - What do I need to install my RCGF 26cc in a Cub 1/4
Old 12-07-2008 | 08:42 PM
Jester241's Avatar
Jester241
Default RE: What do I need to install my RCGF 26cc in a Cub 1/4
Well,for a cub I doubt you'll be putting a spinner on it right? If not,then you wont need a starter because with that electronic ignition,you'll be flip starting it. You will have to use either "tygon" or "neoprene" fuel tubing. Tygon is nice if you can see your fuel tubing so you can actually see the fuel hitting the carb. Neoprene is nice if you cant see it because I think it doesnt tend to expand like tygon. You'll likely only need the small diameter fuel tubing too. You'll want a switch with a charge jack built in and a 4.8v battery pack for the ignition. And like those guys said,you'll need a fuel tank conversion kit for the gas tank. Your motor comes with stand offs and stuff,so thats about all you'll need.
