RCU Forums - View Single Post - new to gassers, need help
Old 12-07-2008 | 10:35 PM
Jester241's Avatar
Jester241
Default RE: new to gassers, need help
You can use ny-rod I guess,but alot of guys actually mount the servo in the engine compartment to avoid having to run a cable into the fuse. Its just recommended that you dont run a metal type throttle linkage into the fuse because it can carry electical interference from the engine back through the metal throttle linkage and screw with your reciever. So basically anything but a solid metal linkage is recommended.
