RCU Forums - View Single Post - OS91 FX
Thread: OS91 FX
Old 12-09-2008 | 03:06 AM
SpeedBoy's Avatar
SpeedBoy
Default RE: OS91 FX
Hi Dar ,
Mmmm interesting points you say ..... I have some questions though
You say that the tips of the prop must promote/have smooth shape to produce good thrust right .... and what if I modify the airfoil trying to leave a smooth shape ( as the pic below ) including the original shape of the tips ?? will work ???
What exactly you mean with chopped prop ? .... to shortened .... ???
Why you say that a shortened prop will take ages to produce effective thrust ???
I have reduced one inch a prop and also reduced its airfoil with good results and another props with only reduced airfoil with awesome results , this is what makes me think that "probably" my crazy thoughts about an aggresive pitch with 9" could work , not sure at all as I only have reduced one inch and that's the reason why I'm making a lot of questions and I like to learn from others .
Ahh and I suggested 12x14 because I saw a guy in the thread you mentioned using that prop and that made me think that exist .
Thanks in advance
P.S. Sorry to kidnap the thread freakingfast .
ID:	1086549   Click image for larger version
