RCU Forums - View Single Post - Where To Find Poulan 46cc Engine?
Old 12-10-2008 | 07:58 PM
av8tor1977's Avatar
av8tor1977
Default RE: Where To Find Poulan 46cc Engine?
Either way should work fine.
Another method I have been thinking about is making a collet type setup like is used on glow engines. You know; it uses a split collet on the crank, and then a prop driver hub with a taper that fits the collet.
AV8TOR
