RCU Forums - View Single Post - CH Ignition- G62
Old 12-11-2008 | 06:22 PM
Charley
Default RE: CH Ignition- G62
ORIGINAL: tkg
We're flexible, you can have your G-62 either way. The CHXL conversion will now be $10 less than the orginal CH set up.
I thought that was what I saw on your web site and Ralph's too. MY G38 conversion kit replaced the flywheel and coil and added the CHSL ignition, sensor & mount. Neat setup.
One question: I have the engine timed to fire the ignition @ 30 degrees BTDC when I turn the crank slowly by hand. Will it retard the spark timing when flipped rapidly or is it gonna bite me? [X(]
CR
Edit: Hmmmm, guess I could check and see......
