CH Ignition- G62
TX
ORIGINAL: tkg
We're flexible, you can have your G-62 either way. The CHXL conversion will now be $10 less than the orginal CH set up.
One question: I have the engine timed to fire the ignition @ 30 degrees BTDC when I turn the crank slowly by hand. Will it retard the spark timing when flipped rapidly or is it gonna bite me? [X(]
CR
Edit: Hmmmm, guess I could check and see......
WY
Just crank it like you mean it and the ignition will auto retard. A lazy, limp wristed flip might get you bit.
The auto shift point is around 200 rpm. A CH unit can tell RPM speed in a single turn.
