RE: Picking up new plane tomorrow!
Here's a method to mount the cowl that will protect it from cracking around the screw holes. Use a bit of fuel tubing to make a grommet out of. Drill the hole in the cowl a bit larger than the screw. Then when you tighten the screw it will expand the fuel tubing. This absorbs the shock of vibration from the engine and will keep the cowl from cracking around the screws.
Ken
