RCU Forums - View Single Post - Golden Rods
Thread: Golden Rods
Old 12-12-2008 | 12:50 PM
jrpav1
My Feedback: (17)
Default RE: Golden Rods
I've used the Sullivan Carbon fiber pushrods too - they work OK but like Ed said you have to check your elevator trim at the start of a day's flying. I've never flown with a full carbon DEP setup (like the Central DEPS) but I don't see how they would be much better as far as the trim issue goes. The fact is a wooden airplane with a long fuse is going to expand / contract ever so slightly whereas the pushrod may or may not change it's length at the same rate. With either type of pushrod setup you do need to support them well or you'll have a mushy elevator linkage. Not good. And yes the standard Nyrods will not work well in a Pattern plane so don't even think about it. Some guys use pull-pull cables for the elevator but that's a whole 'nother can of worms. I think I'm going to stick with the Sullivan carbon rods until I find a better way.
John Pavlick
Team Black Magic, Tech-Aero Designs
