RCU Forums - View Single Post - Panel lines on Monokote?
Old 12-12-2008 | 10:30 PM
LDM
My Feedback: (15)
Default RE: Panel lines on Monokote?
In order to get depth with sharpies its worth useing two types , experiment on the bottom elevator for best effect .
Example on Gray monocote you may want to try a think black sharpie then a thin siler one over that line -or thin silver first then thin black over that .
Or you get -model master premixed for spray painting "exaust " simply take a air gun and cut about 10 -sheets of 12 by 12 card board stock poster board .
Line your sheet up where you want the line , spray with at least 12" from the plane and you will have a sharpe line and on the other side a buff -wing effect line .
Try to keep all the sharpe lines forward and the buffed lines towards the tail as they would be from the wind
