RCU Forums - View Single Post - NEED HELP!
Thread: NEED HELP!
Old 12-13-2008 | 05:48 PM
Lnewqban's Avatar
Lnewqban
Default RE: NEED HELP!
Super:
My three advices:
1) Keep your hands away from the propeller at all times.
2) Avoid strong wind during the first attempts (6 to 8 miles/h max.).
3) Do not over-control your model; it will take off by itself at full throttle, and it will land also by itself with a little more than minimum throttle and just a little elevator up at final flare. Also turn mostly using gentle and constant rudder input; just avoid ailerons at the beginning.
Also, check these links:
http://www.geistware.com/rcmodeling/...er_1/index.htm
http://www.dmac.org.uk/
http://www.masportaviator.com/ah.asp?CatID=8&ID=141
http://www.lferc.com/Tips/set_up_for_success.php
Best luck!
