RCU Forums - View Single Post - Homelite 30cc Problem how to fix?
Old 12-13-2008 | 10:21 PM
Ram Jet's Avatar
Ram Jet
Default RE: Homelite 30cc Problem how to fix?
Is it a reed valve engine? If so your reeds aren't seating. If not you likely have a severe crankcase leak somewhere. Check the crankshaft seals, if it has them. Crankcase gasket? In take manifold leak? I doubt it because the intake maifold is probably cast into the crankcase.
this website is for trimmers but you might find your engine here:
http://www.odref.com/homelite/string-trimmer/imdex.htm
Bill
