RCU Forums - View Single Post - 60 size engine on a 40 size trainer
Old 12-14-2008 | 06:27 AM
Alex7403's Avatar
Alex7403
Default RE: 60 size engine on a 40 size trainer
ORIGINAL: opjose
ORIGINAL: alex7403
if you are talking about the ARF:
Tower trainer 40 ARF with 61 FX not a good idea.
i'm not sure the tower trainer 40 ARF engine mount would accept the 61 FX!!!!
and the fire wall is designed for that mount only!!!
Actually it works just fine.
The FX is not as powerful as a .55 AX so there is little additional stress on the plane.
It fits and mounts w/o problems.
In the picture:
Tower trainer 40 ARF engine mount: ~35.4 mm
Width of OS 61 FX for mount 43 mm
In the ARF version of tower trainer 40 you cannot change the mount, I was looking for something similar with the same bolt pattern but didn’t find.
61 FX will not fit into tower trainer 40 ARF engine mount.
Alex
ID:	1089341   Click image for larger version
