RCU Forums - View Single Post - Exceed Dynamite problems
Old 12-14-2008 | 12:29 PM
SAVAGEJIM's Avatar
SAVAGEJIM
Default RE: Exceed Dynamite problems
ORIGINAL: Emaxx Bash
Hi I have just gotten my Exceed Dynamite truck and i charged it for 8 hours the first time and i took it out and it ran great for about 5 minutes then it started stuttering in forward and reverse. Is this the battery life?
Batt life should not cause twitching of any kind. If teh batt is low, the failsafe should kick in and your RC should go to idle and brake.
A sign of a low batt is when you work teh controls, the servos turn much more slowly, but they should never twitch
You most likely are suffering from interference. Check what channel you are on and be certain no one else is on your channel. If someone else is, you MUST change your radio channel
If interference is not the problem, then it could be problems with the radio itself. Be sure to report your problems to Andy, he will either replace your radio or let you know how to fix your problems.
I personally recommend you get an aftermarket radio. These RTR radios are disposable and are not too good. You can find a decent 2channel radio, like a Futaba 2PH, for no more than $50 USD.
