RCU Forums - View Single Post - almost there now...the elusive prop adapter
Thread
12-14-2008 | 04:10 PM
6
captinjohn
Jan 2002
12,957
Hesperia Michigan, MI
RE: almost there now...the elusive prop adapter
If you have a good fit on the taper, you do not need a key-way. The hub should come off taper kinda hard and with the use of a little loctite...its there just as good as if a key was used. Also on gas /glow you do not worry about timing. Capt,n
Reply
Like
captinjohn
View Public Profile
Send a private message to captinjohn
Find More Posts by captinjohn
View iTrader Profile
