RCU Forums - View Single Post - Need Advice
Thread: Need Advice
Old 12-14-2008 | 06:31 PM
Jim Thomerson
Default RE: Need Advice
If your CG is in the right place, you only need about 20 degrees of throw each way in both elevator and flaps. (I generally go 25 just to have a little margin) I would start out with the handle line spacing to give you that much throw with comfortable hand movement. Widen or lessen the spacing, if needs be, as you become more accustomed to the airplane.
