RCU Forums - View Single Post - Wrong carbs on your engines
Old 12-16-2008 | 11:21 AM
jack1933
Default RE: Wrong carbs on your engines
ORIGINAL: altavillan
There is a simple trick to get your engine to draw plenty of fuel at or near WOT. Just close the choke an amount needed to increase fuel draw. By use of a servo or restrict it's movment to not go all the way open. Perfect solution for the BME 115 engine that tends to run out of draw at WOT.
Was n ot aware the BME engine now was "running out of fuel" thought the wga-7/9 was the perfect carb for the engine. I tried not to mention brands here Tom, will you please jump in here and explain. Thanks
Jack
