Wrong carbs on your engines
#76
I don't have any 150's so I'm keeping my mouth shut. However, if any of my smaller engines don't run the way I think they should I'll experiment with carbs if I believe it to be the problem. Just helped solve an engine issue with another RCU member by changing carbs. In that case it was the difference between a real Walbro and a Chinese clone of the same model.
#77
OK
ORIGINAL: captinjohn
Jack, are these engines you are talking about that will not go rich, is that on a test stand or in airplane? Just for data on this...what Prop...what is hi RPM (average will do)....what is the placement of fuel tank and how big of lines and or filters are you using? I caanot for the life of me figure out why five of the same carbs will not richen up. For every happening there is a cause...I would think! Thanks, Capt,n[X(]
Jack
#78
What is the difference between a wga7/9 carb and a BME116 carb (Wga7/9) carburator? Like in last sentence! Is one a real Walbro and the other a clone like TOM stated? Capt,n
#79
OK
Jack
#80
I was not referring to a carb for a BME engine when I mentioned a cloned carb. Much smaller engine and carb product involved in that one. Didn't mean to confuse the issue.
I believe jack had the wga-7/9 on a 150 where BME uses it on a 116.
#81
OK
ORIGINAL: Tired Old Man
#82
Is it possible for the average engine enthusiast to notice or see the difference between a Real or cloned Walbro carburetor? Thanks Capt,n
#83
My Feedback: (13)
OH
you know i only had two china made engines (same manufacturer), and found that the engine started easier and could richen both needles slobbery rich with a real walbro carb.
the engine just responded better with needle adjustment with the real walbro.
#84
CA
The WGA series (7/9) have a familiar venturi. They tune easy and with their moulded venturi have positive fuel draw. The next size step up in carb series is the WB. It has a machined bore with almost no venturi. I would conclude there really isn't much in the way of a variety of Walbro's to choose from in the 150cc size and up and none are going to be designed for airplane use. So they have to make do with whats available.
Engine builders also have to take into account, needle placement, throttle, choke and fuel supply locations, further limiting choices.
#85
ORIGINAL: closetguy
#86
The cloned Walbros only look like a Walbro, they do not possess the Walbro name on the cover plates. Interesting that Walbro parts from equal model types will generally intechange with the cloned versions. The same pretty much applies to the Emas versions of Tillotsen carbs. Another RCU memeber and I were discussing an issue he was experiencing on an engine using a cloned Walbro. After a lot of trial and error and discussion he decided to install a new Walbro carb of the same model type. Voila, problems went away.
The Walbro carb clones brings up a rather funny anecdote from two years ago. Seems RC Ignition Ralph had mentioned that Walbros were being cloned and a few were telling him this was not so. Better still was that I was standing in Ralphs shop holding one of the clones in my hand while that discussion was taking place.
#87
OK
ORIGINAL: altavillan
#88
OK
Regards
Jack
