RCU Forums - View Single Post - Looking for a post on cutting a cowl
Old 12-16-2008 | 12:45 PM
bruce88123
Default RE: Looking for a post on cutting a cowl
ORIGINAL: goirish
Well lets see if I can do that
Note that the software is looking for the square brackets around the word "quote" to start and stop the quoted lines, and that I added an extra space in my example (bolded above) to prevent them from being picked up as markers in THIS message. You also have to remember to use the forward slash "/" for the "ending" quote mark.
It's easy. The software looks for the combination of [ quote ] and [ /quote ], takes everything between the two and draws the box around it to set it off. It also is programmed to insert the word "ORIGINAL" and the name of the poster. Every time you type in the [ quote ] and [ /quote ] it will create an additional "quote" box.
Hummm!!! I didn't get the 2nd quote box.
You probably forgot to install the second set of [ ] [/] brackets.
