RCU Forums - View Single Post - Chipmunk rudder pull pull
Old 06-04-2003 | 04:38 PM
r1morris
Default Chipmunk rudder pull pull
When you install the inner yellow nyrod use some length like 4 to 6 inches inside the fuse I found that it's easier to run the cable and does not create any friction that I can detect. it also makes it easy to work on the pull -pull system when needed.
