RE: Water Float question?
You get a little turn out of the Vertical Stab, but not enough to taxi much. The rudder will dig into the snow if you leave it on. You won't be able to get the speed to get off the snow. The tubing is vinyl tubing from Home Depot. No sharp corners or it will kink and mess with the engine performance.
