RE: Comp ARF Flash update
Hello,
Maybe a stupid question but how do you measure your aileron throws ? from the wing tip side or from the flap (fuselage) side ?
The manual says aileron 20mm up, 22mm down but I can only reach 17mm from the wing tip side before binding !
I also got trouble with the flap settting, at the neutral position my JR 8411 are very noisy and current consumpsion looks high, 250 to 300 mA for both flaps.
Do I have to sand a little bit the flap lips ?
Do you have any fix for both issues ?
Thanks for your help.
Alain
