RE: help please
If you are use a drill and you say it's turning it fast it might be to fast. This can happen. One person I know put a higher voltage battery on his starter to start a os50 engine. It didn't work because it turned to fast. Try turning the speed down on the drill if it's variable. Other wise try a regular heli starter. Good luck.
