RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
help please
Old 12-20-2008 | 06:27 PM
Default help please
have a problem with a tt36 engine getting fuel glow stick is hot on the plug but just dont fire up not even a pop could it be my starter not turning fast enough? any sugestions?
Old 12-20-2008 | 10:27 PM
Default RE: help please
get an OS?? I know that's not that helpful but TT motors really aren't that great.
Do you see fuel going through the fuel line? what starter are you using?
Old 12-20-2008 | 10:34 PM
getting fuel just not fireing im useing a dewalt drill with a 6mm shaft seems to be turning it fast i have a os 32 think i might just switch them
Old 12-21-2008 | 01:50 AM
Bugzilla's Avatar
Have you started it with that drill before?
Old 12-21-2008 | 06:05 AM
hello did you check to see if glow plug is working pull out and hook up to glow nighter
Old 12-21-2008 | 06:12 AM
Charlie's Avatar
Good idea, the OS 32 is a great motor, a little under powered but a very reliable motor. The TT 36 was a nightmare from day one (they make a great paper weight though ).
Old 12-21-2008 | 11:12 AM
A. J. Clark's Avatar
If you are use a drill and you say it's turning it fast it might be to fast. This can happen. One person I know put a higher voltage battery on his starter to start a os50 engine. It didn't work because it turned to fast. Try turning the speed down on the drill if it's variable. Other wise try a regular heli starter. Good luck.
Old 12-21-2008 | 12:11 PM
well i got my os 32 out of the closet and bench ran it so i know it runs great i put it in the heli and tride to fire it up and nothing so it has to be the drill not spining fast enough my drill has no speed control so im going to lhs to grab a starter shaft and try that never really liked tt engines any ways well ill keep you guys posted and thanks for your help
Old 12-21-2008 | 04:41 PM
well got it fired up finally then my fan came loose and lost all the blades figures right! well should of waited for the lock tight to dry!
any body have that problem yet
