Throttle hold in Acro on 10c
Hi everyone,
I've made a honest attempt to solve this on my own & cannot find the simple solution I'm looking for. I'm trying to lock my throttle like my eclipse radio did. I want to have a safety switch that will lock the throttle after I place the stick at dead idle. I believe the radio has throttle hold, but only in the heli mode. I acro I can only find throttle cut & idle up/down. Those haven't worked as you can still push the throttle far enough that it will overide the amount of drop commanded by the switch because it only goes to 50 or 40%. The only convoluted solution I can come up with is to mix to channel five & set the percentages to 0. Anyone?
Bruce.
